To configure IP unicast routing on the switch:
        Create and configure two or more VLANs.
        For each VLAN that participates in IP routing, assign an
          IP address, use the following command:
configure
              {vlan} vlan_name
            ipaddress [ipaddress {ipNetmask} | ipv6-link-local |
              {eui64} ipv6_address_mask]
        Ensure that
            each VLAN has a unique IP address.
        Configure a default route using the following
          command:
configure iproute add default
          gateway {metric} {multicast | multicast-only |
          unicast | unicast-only} {vr
          vrname}
        Default routes are used when the router
          has no other dynamic or static route to the requested destination.
        Turn on IP routing for one or all VLANs using the
          following command:
enable
            ipforwarding {ipv4 | broadcast | ignore-broadcast | fast-direct-broadcast} {vlan
            vlan_name}
        Configure the routing protocol, if required. For a simple
          network using RIP, the default configuration may be acceptable.
        Turn on RIP or
            OSPF using
          one of the following commands:
enable
            rip
        enable
            ospf
